Lenovo ThinkPad T400s LCD Screen Replacement
  1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
  2. Lenovo ThinkPad T400s LCD Screen Replacement: step 2, image 1 of 1
    • Using the spudger, gently pry off the plastic LCD screen frame around the entire perimeter.
    • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
  3. Lenovo ThinkPad T400s LCD Screen Replacement: step 3, image 1 of 2 Lenovo ThinkPad T400s LCD Screen Replacement: step 3, image 2 of 2
    • Remove the LCD connector by pulling on the ribbon cable at the connection.
  4. Lenovo ThinkPad T400s LCD Screen Replacement: step 4, image 1 of 1
    • Lift the LCD screen out to replace.
Christopher Noone
235 Reputation
1 Guide authored
Cal Poly, Team 6-18, Maness Spring 2015 Member of Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 2,571
