Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement
  1. Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement, Lower Case: step 1, image 1 of 1
    • Shut down your ThinkPad L590 before beginning; do not put it to sleep or hibernate. Disconnect the AC adapter and any peripheral devices (USB drives, external monitors, etc.).
    • Set the computer down with the lower case facing up.
    • Use a Phillips screwdriver to remove the following screws securing the lower case:
    • Six 10 mm screws
    • Three 5.5 mm screws
  2. Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement: step 2, image 1 of 2 Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement: step 2, image 2 of 2
    • Insert an opening pick into the gap between the lower case and chassis.
    • Gently pry around the entire perimeter of the laptop until all of the retaining clips fully release.
  3. Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement: step 3, image 1 of 1
    • Lift off the lower case.
  4. Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: step 4, image 1 of 2 Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: step 4, image 2 of 2
    • Use tweezers to grip the battery connector and pull it directly out of its motherboard socket.
  5. Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement: step 5, image 1 of 1
    • Remove the four 5.5 mm Phillips screws that secure the heatsink.
  6. Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement: step 6, image 1 of 1
    • Use an opening tool or your fingernails to gently "walk" the fan connector out of its motherboard socket.
  7. Lenovo ThinkPad L590 Fan and Heatsink Assembly Replacement: step 7, image 1 of 1
    • Gently lift the fan out of its compartment.
    • If the fan is stuck, use a nylon spudger to carefully pry it loose.
German
392 Reputation
3 Guides authored
Gateway, Team 8-66, Gonzalez Fall 2024 Member of Gateway, Team 8-66, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G66
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 285
