Lenovo ThinkPad HK11e Battery Replacement
  1. Lenovo ThinkPad HK11e Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the Lenovo laptop is shut off.
    • Turn over laptop and lay it on its face exposing the back-plate screws.
  2. Lenovo ThinkPad HK11e Battery Replacement: step 2, image 1 of 1
    • Find the six screws that hold together the back plate.
    • Carefully unscrew the six 3.3 mm screws that fasten the back plate using the T5 Torx screwdriver.
  3. Lenovo ThinkPad HK11e Battery Replacement: step 3, image 1 of 1
    • Use a plastic opening tool or a spudger to carefully remove the back plate.
  4. Lenovo ThinkPad HK11e Battery Replacement: step 4, image 1 of 1
    • Battery is located in the bottom right portion of the laptop.
    • Find the three screws that mount the battery.
    • Carefully unscrew the three 3.5 mm screws that fasten the battery down using the T5 Torx screwdriver.
  5. Lenovo ThinkPad HK11e Battery Replacement: step 5, image 1 of 1
    • Notice a connector that joins the battery to the laptop.
    • Slowly disconnect the connector by pulling back on the six-wire harness.
  6. Lenovo ThinkPad HK11e Battery Replacement: step 6, image 1 of 1
    • Remove the battery from its assigned location.
  7. Lenovo ThinkPad HK11e Battery Replacement: step 7, image 1 of 1
    • Reverse steps to mount new battery correctly.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 67
All Time: 1,482
