Lenovo ThinkPad Edge E530 HDD Replacement
Video Overview
  1. Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: step 1, image 1 of 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: step 1, image 2 of 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: step 1, image 3 of 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): step 2, image 1 of 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): step 2, image 2 of 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): step 2, image 3 of 3
    • There are 2 x philips screws, securing the HDD Caddy Case. Remove them and slide the HDD to disconnect it from the SATA Connector.
    • The Caddy Case is held to the HDD by 4x Phillips screws. Remove them and separate the HDD from the case.
    • After installing the new HDD you must install a new OS or clone your old HDD.
    • You can install SATA HDD, 2.5" up to 1TB.
    • Did you do it successfully?
7 other people completed this guide.
ZFix
191,368 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,468 Guides authored
2 Comments
Since you mention cloning, it would be good to know how to clone one’s old drive. Would this also clone any errors on the oldrive and then put them on the new drive???
David Abineri - Reply
Thanks for the guide. It also works for the ThinkPad Edge E531 model.
Célestin Taramarcaz - Reply
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 41
All Time: 10,222
