Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement
Video Overview
  1. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, HDD Cover: step 1, image 1 of 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, HDD Cover: step 1, image 2 of 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, HDD Cover: step 1, image 3 of 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Fan / Cooling System: step 2, image 1 of 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Fan / Cooling System: step 2, image 2 of 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Fan / Cooling System: step 2, image 3 of 3
    • Disconnect the Fan cable.
    • Remove the 2x screws from the Fan module.
    • Unscrew 4x screws around the processor.
    • Carefully lift the Cooling System.
  3. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: step 3, image 1 of 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: step 3, image 2 of 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: step 3, image 3 of 3
    • Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Separate the Fan from the Heat-sink.
  4. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: step 4, image 1 of 1
    • Use a soft anti static brush and clean the Heat-sink on the inside.
    • Before installing a new Cooling System or reinstalling the old one, you must clean the processor from the old thermal compound and put a new one.
  5. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Processor / CPU: step 5, image 1 of 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Processor / CPU: step 5, image 2 of 3 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement, Processor / CPU: step 5, image 3 of 3
    • Clean the old thermal compound. Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • To remove the Processor, turn the CPU socket screw 90 degrees to open the socket.
    • Lift the Processor from the socket.
    • Be careful to lift straight up without bending the CPU pins.
  6. Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: step 6, image 1 of 2 Lenovo ThinkPad Edge E530, E530c Processor / CPU Replacement: step 6, image 2 of 2
    • Before you place the new Processor, be sure the socket screw is in the open position.
    • Delicately place the Processor into the socket.
    • Close the socket with the socket screw.
    • Put thermal compound on the processor surface and carefully install back the Cooling system.
3 other people completed this guide.
ZFix
195,943 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
329 Members
1,452 Guides authored
2 Guide Comments
Bonjour, peut-on remplacer le CPU par n'importe quel autre plus puissant, ou y a-t-il des restrictions ?
francoislaurent - Reply
This guide works for E531 as well
adrium - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 31
All Time: 7,845
