Lenovo Tab 2 A10-70 Power Button Replacement
  1. Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: step 1, image 1 of 2 Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: step 1, image 2 of 2
    • Use a plastic opening tool to pry open the back cover of the tablet.
  2. Lenovo Tab 2 A10-70 Power Button Replacement: step 2, image 1 of 1
    • The power button strip is only held in place by a small piece of double-sided tape.
    • Gently use the precision tweezers to separate the power button strip from the interior frame of the tablet.
  3. Lenovo Tab 2 A10-70 Power Button Replacement: step 3, image 1 of 1
    • Be careful with the soldering iron to avoid injury.
    • Remove the power button from the motherboard.
    • Use the soldering iron to heat up the connections. Gently pull away from the motherboard after connections are detached.
3 other people completed this guide.
Tyler Hagenlocher
350 Reputation
2 Guides authored
USF Tampa, Team 12-6, Eyestone Spring 2016 Member of USF Tampa, Team 12-6, Eyestone Spring 2016
USFT-EYESTONE-S16S12G6
4 Members
10 Guides authored
One Comment
Thank you for making this helpfull instrutions.
Where i can get the Buttons?
Simon - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 6,776
