Introduction
All of the processing power of the Lenovo N21 Chromebook comes from its motherboard. In order to fix issues with the RAM, hard drive, CPU, or graphics, the whole motherboard may need replacement. In order to replace the motherboard or the camera, you will need to replace both pieces because they are connected.
Be careful when dealing with the motherboard. It is very sensitive due to its small parts. When removing it, take extra care not to touch the CPU because oil from fingers may damage the piece.
Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
My replacements did not come with the trackpad zif. I had to remove from the old part and move to the new part.
Remove the keyboard and trackpad panel away from the device.
Has anyone gone through the experience of replacing JUST the keyboard? It looks like they are available as a separate component, e.g. https://www.ebay.com/itm/New-for-Lenovo-... but I haven’t found a tutorial on removing the keyboard from its bezel. Thanks!
Use a screwdriver to remove the single 3mm Phillips screw that is holding the WiFi card in place.
Carefully pry off the six small rubber pads around the screen with a plastic opening tool to expose the screws.
Remove the two 4.0 mm Phillips screws from the right side of the camera.
Once the two screws are removed, carefully pull the camera off the top of the screen.
3 other people completed this guide.
Where is write Protect Screw ???
Please
Lenovo N21 Chrome Book
MAC IT - Reply
