You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Removal of the back panel is crucial for repairing the hardware in the computer or the back panel itself due to dents/other damages. This guide will walk you through the process of how to remove and/or replace the back panel of your device.
Parts
No parts specified.
  1. Begin by turning your closed laptop so that you are looking at the bottom panel.
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Apple Watch Kits
    Screen and battery repairs just got easier.
    Shop Now
    Apple Watch Kits
    Shop Now
  3. Locate the 10 screws (6mm) around the border of the panel. Using the Torx T5 Screwdriver, remove the screws.
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  4. Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
Andria Chen
570 Reputation
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 178
