Lenovo Ideapad Flex 4-1570 RAM Replacement
  1. Lenovo Ideapad Flex 4-1570 RAM Replacement, Back Panel: step 1, image 1 of 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 RAM Replacement: step 2, image 1 of 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 RAM Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 RAM Replacement, RAM: step 4, image 1 of 1
    • Gently remove the RAM cover with a spudger.
    • Although a metal spudger is shown in the photo, an ESD-safe nylon spudger is recommended.
  5. Lenovo Ideapad Flex 4-1570 RAM Replacement: step 5, image 1 of 1
    • Do not attempt to pull the RAM out without first pulling up the metal release brackets.
    • Gently remove the RAM by pulling up the metal release brackets, pushing the RAM forward out of its port, and lifting it up and out.
1 Guide Comment
Simple and easy to follow guide, thank you! The Flex 4 I was working on had two additional 10mm screws in the top corners, this may be a later revision.
Chris Horry - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 352
