Introduction
This guide will show you how to replace the Wi-Fi card in the Lenovo Ideapad 310-15IKB. This should only take around 7 minutes to do and it is very simple. You will only need a number 0 Phillips head screw driver and a spudger.
Flip the laptop over so the back panel is facing up.
Remove the single 6 mm screw from the L-shaped panel using a Phillips #0 screwdriver.
Almost done!
