Introduction
Use this guide to replace a single key on your Lenovo IdeaPad Y510P. This repair may be needed if a stuck key broken key impedes typing ability. Repeated use of a key can cause the key to feel as if it sticks and does not press back immediately. By following the steps listed in the guide, you will be walked through a simple disassembly of any individual key, and how to replace it. Use of too much pressure at any point throughout the guide can damage the mounting point for the key, or key hinge.
Locate the key that is behaving abnormally.
Gently insert a spudger underneath the key cap.
If you adjusted the key hinge, rather than replacing it, test the key to ensure the behavior was fixed. If the key still sticks on press, repeat the guide and replace the hinge as compared to adjusting it.
2 other people completed this guide.
