Introduction
This guide will assist with the replacement of the battery. The user should be familiar with using a screwdriver, and should be able to keep track of all removed screws. Be careful of any sharp edges within the computer itself.
Remove the back panel by removing all screws. Use a PH000 screwdriver head.
Make sure to also remove the hinge screws.
Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
Be careful to keep track of all removed screws.
Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
To remove the connection, please pull firmly, as it well secured.
