Lenovo IdeaPad U530 Touch Battery Replacement
  1. Lenovo IdeaPad U530 Touch Battery Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaPad U530 Touch Battery Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaPad U530 Touch Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch Battery Replacement: step 2, image 1 of 2 Lenovo IdeaPad U530 Touch Battery Replacement: step 2, image 2 of 2
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch Battery Replacement: step 3, image 1 of 1
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch Battery Replacement: step 4, image 1 of 2 Lenovo IdeaPad U530 Touch Battery Replacement: step 4, image 2 of 2
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch Battery Replacement: step 5, image 1 of 1
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch Battery Replacement: step 6, image 1 of 1
    • Simply lift the battery out of the computer, and acquire a replacement.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 23
All Time: 2,766
