Lenovo IdeaPad U350 Hardrive Replacement
  1. Lenovo IdeaPad U350 Hardrive Replacement, Hardrive: step 1, image 1 of 1
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are attached to the panel. When unscrewing, be sure to stop when you here a click.
  2. Lenovo IdeaPad U350 Hardrive Replacement: step 2, image 1 of 1
    • Lift the back panel from the side closest to the battery and remove the panel.
  3. Lenovo IdeaPad U350 Hardrive Replacement: step 3, image 1 of 2 Lenovo IdeaPad U350 Hardrive Replacement: step 3, image 2 of 2
    • Slide the hard drive to the right, away from the RAM modules.
    • Lift the hard drive from the side closest to the RAM modules.
    • When re-inserting the hard drive, ensure that the copper contacts on the drive's connector are facing upwards.
James Morizzo
496 Reputation
3 Guides authored
USF Tampa, Team 1-4, Hickman Fall 2014 Member of USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,792
