Lenovo IdeaPad 300-17ISK Keyboard Replacement
    • The battery for this device is not easily accessible and cannot be easily removed. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you drain the battery completely before you begin this replacement.
  1. Lenovo IdeaPad 300-17ISK Keyboard Replacement, Keyboard: step 2, image 1 of 1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Keyboard Replacement: step 3, image 1 of 3 Lenovo IdeaPad 300-17ISK Keyboard Replacement: step 3, image 2 of 3 Lenovo IdeaPad 300-17ISK Keyboard Replacement: step 3, image 3 of 3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Keyboard Replacement: step 4, image 1 of 2 Lenovo IdeaPad 300-17ISK Keyboard Replacement: step 4, image 2 of 2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
Ammar Dodin
1,057 Reputation
6 Guides authored
UC Davis, Team 1-3, Rodger Winter 2017 Member of UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 5,562
