Lenovo IdeaPad 110-15IBR Hard Drive Replacement
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: step 2, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: step 3, image 1 of 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: step 3, image 2 of 2
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: step 4, image 1 of 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: step 4, image 2 of 2
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: step 5, image 1 of 1
    • Remove hard drive from housing.
Saddam Alsinai
669 Reputation
4 Guides authored
UW Tacoma, Team S3-G4, Liner Fall 2017 Member of UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 43
All Time: 19,868
