Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement
  1. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement, WiFi/ Bluetooth Card: step 1, image 1 of 1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: step 2, image 1 of 2 Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: step 2, image 2 of 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: step 3, image 1 of 1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: step 4, image 1 of 2 Lenovo IdeaPad 100s-14IBR WiFi/ Bluetooth Card Replacement: step 4, image 2 of 2
    • Remove the tape and unscrew the single 2mm PH00 screw.
    • Pull out the current WiFi/Bluetooth card, unplugging the two wires connected to it.
Follow the guide in reverse to reassemble your device.
Congratulations on successfully completing the WiFi/Bluetooth card replacement for your Lenovo IdeaPad 100s-14IBR laptop! By following this guide, you've taken a proactive step towards improving your device's wireless capabilities, ensuring a more seamless and reliable connectivity experience.
Remember to power on your laptop and test the new card to ensure it functions correctly. If you encounter any issues, double-check your connections and revisit the steps to ensure everything is in place. Feel free to revisit this guide or seek additional assistance if needed.
Bin Feng
259 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 34
All Time: 2,262
