Toshiba Satellite C50D-A Fan Replacement
  1. Toshiba Satellite C50D-A Fan Replacement, Battery: step 1, image 1 of 1
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A Fan Replacement: step 2, image 1 of 2 Toshiba Satellite C50D-A Fan Replacement: step 2, image 2 of 2
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A Fan Replacement, Lower Case: step 3, image 1 of 2 Toshiba Satellite C50D-A Fan Replacement, Lower Case: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A Fan Replacement: step 4, image 1 of 1
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A Fan Replacement: step 5, image 1 of 1
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A Fan Replacement: step 6, image 1 of 3 Toshiba Satellite C50D-A Fan Replacement: step 6, image 2 of 3 Toshiba Satellite C50D-A Fan Replacement: step 6, image 3 of 3
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A Fan Replacement, Fan: step 7, image 1 of 3 Toshiba Satellite C50D-A Fan Replacement, Fan: step 7, image 2 of 3 Toshiba Satellite C50D-A Fan Replacement, Fan: step 7, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the one 1.5mm screw.
  8. Toshiba Satellite C50D-A Fan Replacement: step 8, image 1 of 1
    • Lift the fan up and blow compressed air or replace with a new one.
    • Blow compressed air into the spirals in the middle of the fan.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,455
