Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement
  1. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, Side Panel: step 1, image 1 of 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: step 2, image 1 of 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, USB 3.0 Expansion Card: step 3, image 1 of 1
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the expansion card retaining screw.
  4. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: step 4, image 1 of 1
    • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
  5. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: step 5, image 1 of 1
    • With moderate force, pull straight up on the expansion card to remove it from the computer.
3 other people completed this guide.
Timothy Grebe
1,634 Reputation
9 Guides authored
Cal Poly, Team 10-39, Amido Fall 2014 Member of Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Members
18 Guides authored
One Comment
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
TheLOD2010 - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,117
