Lenovo G500S Touch Back Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Lenovo G500S Touch Back Panel Replacement, Battery: step 1, image 1 of 3 Lenovo G500S Touch Back Panel Replacement, Battery: step 1, image 2 of 3 Lenovo G500S Touch Back Panel Replacement, Battery: step 1, image 3 of 3
      • Make sure that your device is powered off and unplugged from the power source.
      • Flip your device over so that the back is facing you.
      • Using your fingers, push the tabs in opposite directions to eject the battery.
      • Remove the battery from the device.
      Ask FixBot
    1. Lenovo G500S Touch Back Panel Replacement, Back Panel: step 2, image 1 of 2 Lenovo G500S Touch Back Panel Replacement, Back Panel: step 2, image 2 of 2
      • Remove the three 4mm screws on the back cover using the Phillips #00 screwdriver.
      • Remove the back cover from the device.
      Ask FixBot
Justin Ogihara
31,605 Reputation
52 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 69
