Lenovo G50-80 80E5 Removing top panel Replacement
  1. Lenovo G50-80 80E5 Removing top panel Replacement, Battery: step 1, image 1 of 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Removing top panel Replacement: step 2, image 1 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 2, image 2 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 2, image 3 of 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Removing top panel Replacement: step 3, image 1 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 3, image 2 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 3, image 3 of 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Removing top panel Replacement: step 4, image 1 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 4, image 2 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 4, image 3 of 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: step 5, image 1 of 2 Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: step 5, image 2 of 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Removing top panel Replacement: step 6, image 1 of 2 Lenovo G50-80 80E5 Removing top panel Replacement: step 6, image 2 of 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: step 7, image 1 of 3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: step 7, image 2 of 3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: step 7, image 3 of 3
    • Locate the 3 screws on the bottom, securing the keyboard.
    • One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Removing top panel Replacement: step 8, image 1 of 1
    • Starting on side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Removing top panel Replacement: step 9, image 1 of 2 Lenovo G50-80 80E5 Removing top panel Replacement: step 9, image 2 of 2
    • Continue prying around top of keyboard
  10. Lenovo G50-80 80E5 Removing top panel Replacement: step 10, image 1 of 1
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Removing top panel Replacement: step 11, image 1 of 1
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Removing top panel Replacement: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Removing top panel Replacement: step 13, image 1 of 2 Lenovo G50-80 80E5 Removing top panel Replacement: step 13, image 2 of 2
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Removing top panel Replacement, Removing top panel: step 14, image 1 of 1
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Removing top panel Replacement: step 15, image 1 of 1
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Removing top panel Replacement: step 16, image 1 of 1
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Removing top panel Replacement: step 17, image 1 of 1
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Removing top panel Replacement: step 18, image 1 of 1
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Removing top panel Replacement: step 19, image 1 of 1
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Removing top panel Replacement: step 20, image 1 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 20, image 2 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 20, image 3 of 3
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Removing top panel Replacement: step 21, image 1 of 1
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Removing top panel Replacement: step 22, image 1 of 2 Lenovo G50-80 80E5 Removing top panel Replacement: step 22, image 2 of 2
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Removing top panel Replacement: step 23, image 1 of 1
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Removing top panel Replacement: step 24, image 1 of 1
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Removing top panel Replacement: step 25, image 1 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 25, image 2 of 3 Lenovo G50-80 80E5 Removing top panel Replacement: step 25, image 3 of 3
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Removing top panel Replacement: step 26, image 1 of 1
    • Top covered removed
Victor
1,282 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 34
All Time: 7,362
