Lenovo Edge Thinkpad E431 Cooling Fan Replacement
  1. Lenovo Edge Thinkpad E431 Cooling Fan Replacement, Bottom Panel: step 1, image 1 of 1
    • Close the device and remove all power cables.
    • Lay the laptop flat with the bottom facing upwards.
  2. Lenovo Edge Thinkpad E431 Cooling Fan Replacement: step 2, image 1 of 1
    • Remove the four 2mm Phillips #00 screws from the bottom panel.
  3. Lenovo Edge Thinkpad E431 Cooling Fan Replacement: step 3, image 1 of 2 Lenovo Edge Thinkpad E431 Cooling Fan Replacement: step 3, image 2 of 2
    • Remove the back panel of the device.
  4. Lenovo Edge Thinkpad E431 Cooling Fan Replacement, Cooling Fan: step 4, image 1 of 3 Lenovo Edge Thinkpad E431 Cooling Fan Replacement, Cooling Fan: step 4, image 2 of 3 Lenovo Edge Thinkpad E431 Cooling Fan Replacement, Cooling Fan: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the nine 2mm Phillips screws from the cooling assembly.
    • Using the tweezers, remove the fan power cable from the motherboard.
  5. Lenovo Edge Thinkpad E431 Cooling Fan Replacement: step 5, image 1 of 1
    • Lift the fan assembly out of the laptop.
Nathan Behan
435 Reputation
3 Guides authored
USF Tampa, Team S3-G3, Nance Spring 2018 Member of USF Tampa, Team S3-G3, Nance Spring 2018
USFT-NANCE-S18S3G3
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 1,143
