Leica CS20 Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
99
All Time:
1,091
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The controller screen has been crashed during the work at construction site. I didn't want to pay 1200 EUR to Leica service center.
    1. Leica CS20 Screen Replacement, Oops..: step 1, image 1 of 1
      • I did it again!
      Ask FixBot
    2. Leica CS20 Screen Replacement, Order a new replacement screen: step 2, image 1 of 1
      • I am tired to pay 1200 EUR to Leica service center, so I ordered a new replacement screent here: www.xsurveying.com/product/new-leica-cs20-digitizer-screen-replacement Price with delivery was around 185 EUR
      Ask FixBot
    3. Leica CS20 Screen Replacement, New touchscreen: step 3, image 1 of 1
      • The package arrived in two weeks. It contained a well packed touchscreen
      Ask FixBot
    4. Leica CS20 Screen Replacement, Prepare a clean area: step 4, image 1 of 1
      • Place controller on a desk
      Ask FixBot
    5. Leica CS20 Screen Replacement, Unscrew all the bolts: step 5, image 1 of 1
      • …and unscrew all the bolts
      Ask FixBot
    6. Leica CS20 Screen Replacement, Remove the bottom lid: step 6, image 1 of 1
      • Also, remove the bottom plastic lid
      Ask FixBot
    7. Leica CS20 Screen Replacement, Unscrew two black bolts: step 7, image 1 of 1
      • …in order to unscrew these two black bolts. Place them separately.
      Ask FixBot
    8. Leica CS20 Screen Replacement, Unscrew 2 bolts: step 8, image 1 of 1
      • These bolts also should be unscrewed.
      Ask FixBot
    9. Leica CS20 Screen Replacement, Remove the back cover: step 9, image 1 of 1
      • After that the controller’s back wall can be removed
      Ask FixBot
    10. Leica CS20 Screen Replacement, Unscrew four bolts: step 10, image 1 of 1
      • Unscrew these four bolts
      Ask FixBot
    11. Leica CS20 Screen Replacement, Unscrew two bolts: step 11, image 1 of 1
      • Unscrew these two small bolts. Place them separately.
      Ask FixBot
    12. Leica CS20 Screen Replacement, Unscrew two plastic bolts: step 12, image 1 of 1
      • Unscrew these two plastic bolts. Place them separately.
      Ask FixBot
    13. Leica CS20 Screen Replacement, Unscrew two bolts: step 13, image 1 of 1
      • Now the last two bolts can be unscrewed
      Ask FixBot
    14. Leica CS20 Screen Replacement, Remove the cage: step 14, image 1 of 1
      • This GNSS antenna connector will be disconnected when you pull out the metal cage
      Ask FixBot
    15. Leica CS20 Screen Replacement, Pull out the board: step 15, image 1 of 1
      • …than pull out this board carefully
      Ask FixBot
    16. Leica CS20 Screen Replacement, See theribbon cable: step 16, image 1 of 1
      • So you wil get an access to this ribbon cable
      Ask FixBot
    17. Leica CS20 Screen Replacement, Unclip the connector: step 17, image 1 of 1
      • ...unclip it!
      Ask FixBot
    18. Leica CS20 Screen Replacement, Unclip the connector: step 18, image 1 of 1
      • Also, unclip the kyocera-connector to this ribbon cable
      Ask FixBot
    19. Leica CS20 Screen Replacement, Act carefully!: step 19, image 1 of 1
      • Proceed with great caution!
      Ask FixBot
    20. Leica CS20 Screen Replacement, Unclip the cable: step 20, image 1 of 1
      • Unclip the touchscreen ribbon cable
      Ask FixBot
    21. Leica CS20 Screen Replacement, Remove the whole board: step 21, image 1 of 1
      • Now you are able to remove the whole board…
      Ask FixBot
    22. Leica CS20 Screen Replacement, Change the screen!: step 22, image 1 of 1
      • And finally, change the screen!
      Ask FixBot
Attached Documents
Sandu Tuzarean
375 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 99
All Time: 1,091
