Lego Dimensions Starter Pack USB Cable Replacement
  1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: step 1, image 1 of 2 Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: step 1, image 2 of 2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack USB Cable Replacement: step 2, image 1 of 1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack USB Cable Replacement: step 3, image 1 of 1
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack USB Cable Replacement: step 4, image 1 of 1
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack USB Cable Replacement: step 5, image 1 of 1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack USB Cable Replacement, USB Cable: step 6, image 1 of 1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
3 other people completed this guide.
Alyssa Lach
509 Reputation
4 Guides authored
IUPUI, Team S5-G2, Baechle Fall 2017 Member of IUPUI, Team S5-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G2
2 Members
8 Guides authored
2 Comments
Where do you buy the USB cable from?
jaimea371 - Reply
mguzmanv - Reply
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 41
All Time: 5,357
