Shop the Holiday Gift Guide
Left Speaker Driver Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
6
All Time:
54
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Left Speaker Driver Installation, Lay the speaker driver in place: step 1, image 1 of 3 Left Speaker Driver Installation, Lay the speaker driver in place: step 1, image 2 of 3 Left Speaker Driver Installation, Lay the speaker driver in place: step 1, image 3 of 3
      • Gently lay the speaker driver into place, making sure the side with gold connector pins lines up with the contacts in the shell.
      Ask FixBot
    2. Left Speaker Driver Installation, Install the speaker driver screws: step 2, image 1 of 3 Left Speaker Driver Installation, Install the speaker driver screws: step 2, image 2 of 3 Left Speaker Driver Installation, Install the speaker driver screws: step 2, image 3 of 3
      • Grip the screws with tweezers while installing them so they don't snap onto the speaker.
      • Use a Torx Plus 3IP screwdriver to install three speaker driver screws:
      • One 6.0 mm‑long screw that's slightly thicker than the other two
      • Two 6.0 mm‑long screws
      • Install the 5.1 mm‑long standoff screw using a small flathead or Torq-Set 6 screwdriver.
      • Apply constant downward force to avoid damaging the screw.
      Ask FixBot
Finish Line
Spencer Day
210,392 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 54
