Use tweezers or your fingers to firmly grip the battery cable's white JST connector and pull straight away from its socket to disconnect it.
Tool used on this step:iFixit Adhesive Remover$19.99
Insert a flat edge of an opening pick into the gap between the battery and the battery well.
Pry the battery up slowly with steady force to release the adhesive.
If you're using adhesive remover, follow these preparation steps first.
Remove the battery.
