Shop the Holiday Gift Guide
Left Joy-Con 2 Battery Installation
View statistics:
Past 24 Hours:
2
Past 7 Days:
5
Past 30 Days:
13
All Time:
121
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Left Joy-Con 2 Battery Installation, Clean the frame: step 1, image 1 of 2 Left Joy-Con 2 Battery Installation, Clean the frame: step 1, image 2 of 2
      Tool used on this step:
      Cotton Swabs
      Buy
      • Apply isopropyl alcohol to a cotton swab and wipe any adhesive residue from the frame.
      • The foam on the inside walls of the frame dissolves in isopropyl alcohol. Avoid damaging the foam.
      Ask FixBot
    2. Left Joy-Con 2 Battery Installation, Transfer the foam: step 2, image 1 of 3 Left Joy-Con 2 Battery Installation, Transfer the foam: step 2, image 2 of 3 Left Joy-Con 2 Battery Installation, Transfer the foam: step 2, image 3 of 3
      • If your replacement battery includes new foam, skip this step.
      • Slide an opening pick or fingernail between the foam and the battery, making sure it's completely below the foam's adhesive.
      • Carefully peel the foam sticker, including its adhesive, off the old battery. Avoid stretching or tearing the foam.
      • If the foam does tear, apply the pieces to the replacement battery in their original shape.
      • Apply the foam sticker to the new battery so the edges of the foam are aligned with the edges of the battery.
      Ask FixBot
    3. Left Joy-Con 2 Battery Installation, Install the battery: step 3, image 1 of 3 Left Joy-Con 2 Battery Installation, Install the battery: step 3, image 2 of 3 Left Joy-Con 2 Battery Installation, Install the battery: step 3, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • If your replacement battery came with adhesive pre-installed, peel off any adhesive liners.
      • If your replacement battery doesn't include new adhesive, use thin, double-sided tape instead. If you're using our pre-cut card, cut one of the 5 mm strips so it's half as long, and apply the strips to the back of the battery.
      • Align the battery with its housing. Ensure the battery cable lines up with its channel.
      • Lower one side of the battery, then the other, into its housing.
      • Press and hold on the battery for 10 seconds to bond the adhesive.
      Ask FixBot
    4. Left Joy-Con 2 Battery Installation, Install the release button: step 4, image 1 of 3 Left Joy-Con 2 Battery Installation, Install the release button: step 4, image 2 of 3 Left Joy-Con 2 Battery Installation, Install the release button: step 4, image 3 of 3
      • Hold the release button so its smooth face is perpendicular to the controller.
      • Insert the release button into its bracket.
      • If the release pin doesn't stick out of the controller when the button is pressed, the button isn't installed correctly. Re-insert or flip the button and try again.
      Ask FixBot
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 13
All Time: 121
