Shop the Holiday Gift Guide
Left Joy-Con 2 Back Cover Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
2
All Time:
159
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Left Joy-Con 2 Back Cover Installation, Connect the battery: step 1, image 1 of 3 Left Joy-Con 2 Back Cover Installation, Connect the battery: step 1, image 2 of 3 Left Joy-Con 2 Back Cover Installation, Connect the battery: step 1, image 3 of 3
      • Align the battery connector over its socket on the board.
      • Press down on the connector until it's fully seated.
      Ask FixBot
    2. Left Joy-Con 2 Back Cover Installation, Connect the rumble motor: step 2, image 1 of 2 Left Joy-Con 2 Back Cover Installation, Connect the rumble motor: step 2, image 2 of 2
      • Align the rumble motor connector to its socket on the bottom edge of the board and push down until it's fully seated to connect it.
      Ask FixBot
    3. Left Joy-Con 2 Back Cover Installation, Install the back cover: step 3, image 1 of 3 Left Joy-Con 2 Back Cover Installation, Install the back cover: step 3, image 2 of 3 Left Joy-Con 2 Back Cover Installation, Install the back cover: step 3, image 3 of 3
      • Use an opening pick to press and hold the release button.
      • Place the back cover over the controller body so the release button cutout is slightly below the release button.
      • The release button is held down when the release pin is protruding from the frame. If the release button falls out of position, put it back and try again.
      • Press and slide the back cover up until the cutout for the release button is aligned with the button itself.
      • Ensure the rumble motor wires (blue & white) are fully within the frame.
      Ask FixBot
    4. Left Joy-Con 2 Back Cover Installation: step 4, image 1 of 2 Left Joy-Con 2 Back Cover Installation: step 4, image 2 of 2
      • Remove the opening pick.
      Ask FixBot
    5. Left Joy-Con 2 Back Cover Installation, Install the left edge screws: step 5, image 1 of 2 Left Joy-Con 2 Back Cover Installation, Install the left edge screws: step 5, image 2 of 2
      • Install the two screws on the left edge of the controller:
      • One 3.1 mm‑long tri‑point Y00 black screw
      • One 3.0 mm‑long JIS 00 silver screw
      Ask FixBot
    6. Left Joy-Con 2 Back Cover Installation, Install the plastic strip: step 6, image 1 of 3 Left Joy-Con 2 Back Cover Installation, Install the plastic strip: step 6, image 2 of 3 Left Joy-Con 2 Back Cover Installation, Install the plastic strip: step 6, image 3 of 3
      • Align the clips on the plastic strip with their cut-outs on the controller body.
      • Insert the clips on the bottom edge first, then insert the rest so the plastic strip sits flush.
      Ask FixBot
    7. Left Joy-Con 2 Back Cover Installation, Install the right edge screws: step 7, image 1 of 2 Left Joy-Con 2 Back Cover Installation, Install the right edge screws: step 7, image 2 of 2
      • Use a tri‑point Y00 driver to install the two 3.1 mm‑long black screws on the right edge of the controller.
      Ask FixBot
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 159
