Ledlenser Stirnlampe H8R torn cable
  1. Ledlenser Stirnlampe H8R torn cable, Disassemble the lamp: step 1, image 1 of 1
    • turn and pull the silver focus ring and the lamp will open up
  2. Ledlenser Stirnlampe H8R torn cable, Disassemble the lamp: step 2, image 1 of 1
    • Unscrew 2 screws, you need a Torx T6 for this
    • then remove the white part
    • do not touch the LED!
  3. Ledlenser Stirnlampe H8R torn cable, Clean solder joints: step 3, image 1 of 1
    • Remove residue from the torn cable
    • Remove the cable ties
  4. Ledlenser Stirnlampe H8R torn cable, Which wire goes where?: step 4, image 1 of 1
    • Riddle: which wire goes where?
    • red = D+ / black = D-
    • green = VSS / yellow = SW (= switch)
    • white = NTC (= temperature sensor)
  5. Ledlenser Stirnlampe H8R torn cable, Do not forget !: step 5, image 1 of 1
    • To be on the safe side, remove the battery from the battery compartment
    • Attention, before soldering don't forget:
    • Thread the cable through the two housings
    • Thread the cable through the kink protection
  6. Ledlenser Stirnlampe H8R torn cable, Soldering: step 6, image 1 of 1
    • Solder 5 times
    • Secure cable with cable tie
    • Now you can test, but please only briefly, otherwise the LED will get too hot
    • Assemble the lamp!
Follow these steps in reverse order to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Gottfried Silberhorn
901 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 39
All Time: 964
