Leapfrog My Own Leaptop Battery Replacement Guide
  1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: step 1, image 1 of 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Battery Replacement Guide: step 2, image 1 of 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
    PH2 works better.
    me262 - Reply
  3. Leapfrog My Own Leaptop Battery Replacement Guide: step 3, image 1 of 2 Leapfrog My Own Leaptop Battery Replacement Guide: step 3, image 2 of 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
Finish Line
Jonathan Fitzer
584 Reputation
3 Guides authored
USF Tampa, Team 14-6, Lacy Spring 2016 Member of USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Members
6 Guides authored
One Comment
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 67
All Time: 2,925
