LeapPad Ultra Battery Replacement
  1. LeapPad Ultra Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapPad Ultra Battery Replacement: step 2, image 1 of 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapPad Ultra Battery Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapPad Ultra Battery Replacement: step 4, image 1 of 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapPad Ultra Battery Replacement: step 5, image 1 of 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapPad Ultra Battery Replacement: step 6, image 1 of 2 LeapPad Ultra Battery Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
To reassemble the device, follow these instructions in reverse order.
7 other people completed this guide.
Ryan Arredondo
246 Reputation
1 Guide authored
USF Tampa, Team 4-99, Meier Fall 2015 Member of USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 Members
10 Guides authored
4 Guide Comments
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - Reply
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - Reply
What is a spudger and where do I get a battery
P Mac - Reply
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - Reply
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 68
All Time: 16,855
