Turn the tablet so the back is visible.
One at a time, remove the battery covers by sliding them towards the sides and away from the center of the device.
Use a Phillips #1 screwdriver to remove the following screws from the device:
Four 7.0mm Phillips screws
Three 6.0mm Phillips screws
Two 10.0mm Phillips screws
Use a small plastic opening tool to begin separating the colored front cover from the white rear cover of the device.
With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and begin pulling the pieces apart.
Once only the top edge remains connected, simultaneously pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces together.
Use a Phillips #1 screwdriver to remove two 5.5mm screws from the plastic speaker holder.
Use a Phillips #1 screwdriver to remove the following screws:
One 5.5mm Phillips screw holding the screen assembly.
Two 8.0mm Phillips screws holding the motherboard.
Two 6.0mm Phillips screws holding the game cartridge slot.
Three 6.0mm Phillips screws holding the auxiliary board.
Locate the following:
Two positive battery terminals.
Two positive battery wire glue-points.
One terminal at a time, insert a narrow metal spudger through the metal loop of each terminal from the side and pry upwards away from the front cover to release the terminal from the cover.
Two negative battery terminals.
Two negative battery wire glue-points.
One terminal at a time, pinch the battery side of the terminal towards the wire side of the terminal with a finger or thumb, and pull upwards away from the front cover to release the terminal from the cover.
Use the small plastic opening tool to gently lift under the side microphone's black wire to remove the microphone from its slot.
Holding the front cover with one hand and the sides of the motherboard with the other, lift the motherboard away from the front cover.
Front camera lens.
Buttons.
Screen assembly tab locations.
Slide the motherboard in the direction of the game cartridge slot until the motherboard is out from under the metal tabs on the screen assembly.
Carefully flip the motherboard over by pivoting away from the screen assembly along the long edge with the microphone and speaker, as shown.
Open the display connector by lifting on the brown latch with a plastic opening tool or a finger until it is in a vertical position.
Gently pull on the display ribbon cable and it should easily slide out of the connecter.
Speaker wire terminal locations.
Desolder the speaker wire connections at one of the two terminal locations shown.
