Le Pan S Screen Replacement
  1. Le Pan S Screen Replacement, Battery: step 1, image 1 of 1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Screen Replacement: step 2, image 1 of 2 Le Pan S Screen Replacement: step 2, image 2 of 2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Screen Replacement: step 3, image 1 of 1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Screen Replacement: step 4, image 1 of 2 Le Pan S Screen Replacement: step 4, image 2 of 2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
    What is the replacement battery to get? Model,type, anything would help..
    Bg70 - Reply
    what is a spudger? Where do you get it? Are replacement batteries still available somewhere?
    BETH SCHRECK - Reply
  5. Le Pan S Screen Replacement, Screen: step 5, image 1 of 1
    • Remove the tape covering the end of the flat ribbon cable.
  6. Le Pan S Screen Replacement: step 6, image 1 of 2 Le Pan S Screen Replacement: step 6, image 2 of 2
    • Disconnect the display cable connector by gently pulling the white connection head out of its base.
    • Repeat for the cable's other end attached near the top of the tablet.
  7. Le Pan S Screen Replacement: step 7, image 1 of 1
    • Disconnect the flat ribbon cable by disconnecting the zero insertion force (ZIF) connector.
    • This can be done by using a plastic opening tool, spudger, or fingernail to lift the retaining flap.
  8. Le Pan S Screen Replacement: step 8, image 1 of 1
    • Remove the six 2.5 mm Phillips #00 screws securing the green electrical board.
  9. Le Pan S Screen Replacement: step 9, image 1 of 1
    • Use the spudger to remove the vibration controller.
  10. Le Pan S Screen Replacement: step 10, image 1 of 1
    • Remove the four 3.5 mm Phillips #00 screws holding the speakers in place.
  11. Le Pan S Screen Replacement: step 11, image 1 of 2 Le Pan S Screen Replacement: step 11, image 2 of 2
    • Flip the green electrical board back so that the screen is separated from the green board.
    • Be careful not to break the Wi-Fi antenna cable that is still soldered to the plastic casing.
  12. Le Pan S Screen Replacement: step 12, image 1 of 1
    • Remove the seven 3.5 mm Phillips #00 screws that connect the grey backing to the screen.
  13. Le Pan S Screen Replacement: step 13, image 1 of 2 Le Pan S Screen Replacement: step 13, image 2 of 2
    • Take the gray backing off of the screen so that only the back of the LCD display is showing.
  14. Le Pan S Screen Replacement: step 14, image 1 of 1
    • Remove the LCD display by lifting up carefully.
    • Place the display in an area where it will not be damaged.
  15. Le Pan S Screen Replacement: step 15, image 1 of 1
    • Flip the device over to the front.
    • Use a heat gun or hairdryer to help loosen any adhesive present on the screen. Start with a low, evenly applied heat and slowly increase the temperature as needed.
    • If you do not have a heat gun or hairdryer, use the metal opening tools mentioned in Step 16.
    • Use the plastic spudger and the plastic opening tool to prop the screen off of the adhesive at one corner.
  16. Le Pan S Screen Replacement: step 16, image 1 of 1
    • Slide the metal opening tools across the sides of the screen in order to separate the adhesive away from the screen.
    • Continue this process until all the sides of the screen are disconnected from the Le Pan S.
    • Make sure to scrape off any remaining adhesive from the housing before adding the new screen and adhesive.
Maria Dole
395 Reputation
3 Guides authored
IUPUI, Team 2-1, Harley Fall 2015 Member of IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Members
10 Guides authored
One Comment
Where can I find the replacement display screen for my Lepan TC802a tablet.
James
jrmpr@aol.com
James - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,210
