Introduction
If your Lasko 18" Oscillating Pedestal Fan (S18902) is noisier than it used to be, or its fan speed has decreased significantly, it's probably time for some maintenance to restore it to its former glory. Periodically cleaning and lubricating fans is important, not only for their function, but to reduce the risk of fire; the hair and dust that accumulates around the motor is essentially tinder, and a single rogue spark can easily cause a house fire.
This guide demonstrates how to disassemble, clean, and lubricate your pedestal fan.
Unplug your fan before beginning.
Use a Phillips #0 screwdriver to remove the single screw on the back of the motor cover.
Align the "oscillation" and "speed" knobs with their cutouts so they can slide out the housing.
Remove the motor cover.
Use a Phillips #0 screwdriver to remove the four screws securing the two sides of the motor.
Separate the front of the motor slightly to create a 3-4 mm gap; do not fully remove the front section.
Place 2-3 drops of light machine oil into the base of the shaft, then spin the shaft to distribute the lubricant.
