Laser Lens Cleaning
    1. Laser Lens Cleaning, Top Panel: step 1, image 1 of 2 Laser Lens Cleaning, Top Panel: step 1, image 2 of 2
      • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
      • Remove five 7.5 mm Phillips screws on the back of the player.
      Ask FixBot
    2. Laser Lens Cleaning: step 2, image 1 of 2 Laser Lens Cleaning: step 2, image 2 of 2
      • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
      Ask FixBot
    1. Laser Lens Cleaning, Laser Lens Cleaning: step 3, image 1 of 2 Laser Lens Cleaning, Laser Lens Cleaning: step 3, image 2 of 2
      • Locate the lens on the disc drive.
      • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
      • Dip one end of a cotton swab in rubbing alcohol.
      • Lightly dab the swab on the lens. Be very gentle.
      • Let the lens dry before replacing the top plate of the DVD player.
      Ask FixBot
16 other people completed this guide.
Nathan Klammer
521 Reputation
3 Guides authored
Cal Poly, Team 21-20, Maness Fall 2011 Member of Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Members
60 Guides authored
5 Guide Comments
This item was not appropriate, thank you for trying.
bigd734 - Reply Share
Works on Samsung's box(home theater), thank you!
CarlBraun - Reply Share
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - Reply Share
ne fonctionne toujours pas
JEAN PIERRE LARVOR - Reply Share
My problem I think is alignment
James Smith - Reply Share
Past 24 Hours: 22
Past 7 Days: 117
Past 30 Days: 544
All Time: 63,349
