How to Mend a Tear in a Mesh Backpack Pocket
    1. How to Mend a Tear in a Mesh Backpack Pocket, Gathering Proper Tools to Mend Hole in Backpack: step 1, image 1 of 2 How to Mend a Tear in a Mesh Backpack Pocket, Gathering Proper Tools to Mend Hole in Backpack: step 1, image 2 of 2
      • Make sure you have all the necessary tools to mend the backpack including scissors, measuring tape, needle, thread, and thimble (if needed to protect your thumb)
      Ask FixBot
    2. How to Mend a Tear in a Mesh Backpack Pocket: step 2, image 1 of 1
      • Inspect the size of the hole you need to mend. For fairly small holes like so, you can follow the next steps for recommended thread length. If your hole is considerable bigger, consider doubling or even tripling the thread size in the next step.
      Ask FixBot
    3. How to Mend a Tear in a Mesh Backpack Pocket, Measure the Amount of Thread Needed: step 3, image 1 of 1
      • Use the measuring tape to measure how much thread you will need and cut with the scissors. I estimate about 12 inches for a Nickle size tear.
      • Scissors can cut you, so be careful!
      Ask FixBot
    4. How to Mend a Tear in a Mesh Backpack Pocket, Thread Needle: step 4, image 1 of 1
      • Lick the end of the thread and put the end of the thread through the hole in the needle. Leave about an inch of thread trailing off at all times so that the thread doesn't slip back through the needle.
      • Needles are sharp, so be careful. You can use the thimble to protect yourself by putting it on your thumb.
      • You can twist the trailing thread around the main one a couple times to keep needle more secure from falling off.
      Ask FixBot
    5. How to Mend a Tear in a Mesh Backpack Pocket, Start Sewing: step 5, image 1 of 2 How to Mend a Tear in a Mesh Backpack Pocket, Start Sewing: step 5, image 2 of 2
      • Create an anchor to your stitch by weaving the needle through the two sides at the start of the tear. Then tie a knot. Repeat this knot 2-3 times for an "anchor". This will keep your sew strong.
      • Once the anchor is made you can start sewing by looping each side together by weaving the needle through each side of the tear in the fabric and squeeze tight. You should see both sides come together tightly. Repeat this until you reach the end of the tear.
      Ask FixBot
    6. How to Mend a Tear in a Mesh Backpack Pocket, Finish with an Anchor: step 6, image 1 of 3 How to Mend a Tear in a Mesh Backpack Pocket, Finish with an Anchor: step 6, image 2 of 3 How to Mend a Tear in a Mesh Backpack Pocket, Finish with an Anchor: step 6, image 3 of 3
      • Once you reach the end of the tear, you need to make another anchor. To do this you need to loop the thread around two fingers and put the needle through both sides of the tear again. Then put the needle through the hole and tie tight.
      • Repeat this 2-3 times until it feels secure.
      • Cut the excess thread with scissors as close to the fabric as possible.
      Ask FixBot
    7. How to Mend a Tear in a Mesh Backpack Pocket, Finish: step 7, image 1 of 1
      • Once finished it should have all extra thread trimmed off and look neat and tidy for the best hold.
      Ask FixBot
Finish Line
Katie Anne Ginther
177 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 52
Past 7 Days: 345
Past 30 Days: 1,073
All Time: 23,029
