Sanyo VPC-X1200 Button Plate Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
52
All Time:
2,744
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
This guide will help you remove the button plate from a Sanyo VPC-X1200 camera.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Sanyo VPC-X1200 Button Plate Replacement, Back Case: step 1, image 1 of 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: step 1, image 2 of 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: step 1, image 3 of 3
      • Remove the five case screws with a Phillips #00 Screwdriver.
      • Five 3.5mm Phillips Screws
      Ask FixBot
    2. Sanyo VPC-X1200 Button Plate Replacement: step 2, image 1 of 1
      • Gently lift up the back cover and set aside.
      Ask FixBot
    1. Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: step 3, image 1 of 2 Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: step 3, image 2 of 2
      • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
      • Be careful not to rip out the ribbon connector.
      Ask FixBot
    2. Sanyo VPC-X1200 Button Plate Replacement: step 4, image 1 of 2 Sanyo VPC-X1200 Button Plate Replacement: step 4, image 2 of 2
      • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
      • Gently lift ribbon out of the gate and set screen aside.
      Ask FixBot
    1. Sanyo VPC-X1200 Button Plate Replacement, Button Plate: step 5, image 1 of 2 Sanyo VPC-X1200 Button Plate Replacement, Button Plate: step 5, image 2 of 2
      • There are five screws of three different sizes which need removal.
      • One 4.5mm screw
      • Four 3.5mm screws, one on the button side
      • One 5.5mm screws
      Ask FixBot
    2. Sanyo VPC-X1200 Button Plate Replacement: step 6, image 1 of 2 Sanyo VPC-X1200 Button Plate Replacement: step 6, image 2 of 2
      • Slowly lift metal tray to the right.
      • Be careful not to bend the screw tabs or rip out the ribbon cable.
      • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
      Ask FixBot
Anthony Giardina
35 Reputation
7 Guides authored
Cal Poly, Team 7-10, Maness Spring 2010 Member of Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 52
All Time: 2,744
