Sony Vaio SVS151190X Disk Reader Replacement
    1. Sony Vaio SVS151190X Disk Reader Replacement, Hard Drive: step 1, image 1 of 1
      • Using a #1 Phillips screwdriver, remove the two 5mm screws as directed.
      • Slide off the back cover.
      • Ensure different sized screws are kept separate during disassembly.
      Ask FixBot
    2. Sony Vaio SVS151190X Disk Reader Replacement: step 2, image 1 of 1
      • Remove the four 3mm screws using the Phillips #1 screwdriver.
      Ask FixBot
    3. Sony Vaio SVS151190X Disk Reader Replacement: step 3, image 1 of 1
      • Lift out the hard drive and unplug the orange ribbon wire.
      Ask FixBot
    1. Sony Vaio SVS151190X Disk Reader Replacement, Disk Reader: step 4, image 1 of 1
      • To loosen the keyboard, remove the twenty 5mm screws using the Phillips #1 screwdriver.
      Ask FixBot
    2. Sony Vaio SVS151190X Disk Reader Replacement: step 5, image 1 of 1
      • Flip the device over and open it up.
      • Using a plastic opening tool and opening picks, pry off the keyboard from the bottom cover. Start from one of the corners of the device and work your way around.
      • The bottom cover is somewhat fragile, do not be too forceful when prying off the keyboard.
      Ask FixBot
    3. Sony Vaio SVS151190X Disk Reader Replacement: step 6, image 1 of 2 Sony Vaio SVS151190X Disk Reader Replacement: step 6, image 2 of 2
      • The ribbon wire that attaches the keyboard and bottom cover is fragile, take care during removal.
      • Remove the keyboard from the bottom cover and place it down as demonstrated.
      • Carefully pull the plastic tab and remove the ribbon wire.
      Ask FixBot
    4. Sony Vaio SVS151190X Disk Reader Replacement: step 7, image 1 of 2 Sony Vaio SVS151190X Disk Reader Replacement: step 7, image 2 of 2
      • Slightly pull up the black tape covering the disk drive's ribbon wire.
      • Pull up the blue plastic strip attached to the ribbon wire and remove the ribbon wire from the port.
      • Detach the ribbon wire from the fan so the disk reader can be removed.
      Ask FixBot
    5. Sony Vaio SVS151190X Disk Reader Replacement: step 8, image 1 of 1
      • Remove the two 3mm screws using the Phillips #1 screwdriver.
      Ask FixBot
    6. Sony Vaio SVS151190X Disk Reader Replacement: step 9, image 1 of 2 Sony Vaio SVS151190X Disk Reader Replacement: step 9, image 2 of 2
      • Take out the black plastic covering.
      • Remove the disk reader.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 56
All Time: 1,190
