Shop the Holiday Gift Guide
MSI 17" GP72VR Keyboard Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
9
Past 7 Days:
63
Past 30 Days:
275
All Time:
3,208
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The goal is to replace a keyboard that has been trashed by 4 years of impetuous gaming with a new one.
    1. MSI 17" GP72VR Keyboard Replacement, Remove the bottom: step 1, image 1 of 3 MSI 17" GP72VR Keyboard Replacement, Remove the bottom: step 1, image 2 of 3 MSI 17" GP72VR Keyboard Replacement, Remove the bottom: step 1, image 3 of 3
      • Flip the PC over; the screen clutch hinge is at the top of the photo
      • Tools: Phillips #0 screwdriver, flathead screwdriver, a magnet on the blade of the Phillips screwdriver makes it easier to recover the screws. Here magnet came from a HDD. A lamp allows you to see the screws at the bottom of the holes.
      • Unscrew the 18 bottom screws
      • Remove the bottom using an opening pick and a flathead screwdriver.
      Ask FixBot
    2. MSI 17" GP72VR Keyboard Replacement, Free the motherboard from the connectors (1): step 2, image 1 of 3 MSI 17" GP72VR Keyboard Replacement, Free the motherboard from the connectors (1): step 2, image 2 of 3 MSI 17" GP72VR Keyboard Replacement, Free the motherboard from the connectors (1): step 2, image 3 of 3
      • Take out the optical drive (black circle in the photo) which is no longer screwed in (a bottom screw you already removed secured it).
      • Unscrew the 2 screws securing the connector that connects the optical drive to the motherboard (yellow circle) and unplug the connector.
      • Disconnect the cable connecting the motherboard to the trackpad board (orange circle). the lock pulls horizontally. the cable passes under the lock, between the board and the lock.
      • Unplug the socket of the cable connecting the speakers to the motherboard (green circle). The socket is pulled horizontally.
      Ask FixBot
    3. MSI 17" GP72VR Keyboard Replacement, motherboard connections (2): step 3, image 1 of 2 MSI 17" GP72VR Keyboard Replacement, motherboard connections (2): step 3, image 2 of 2
      • Disconnect the cable connecting the motherboard to the USB circuit - card reader - start buttons (red circle). The lock tilts upwards, the cable passes under the lock.
      • Unplug the power cable plug on the motherboard (green circle). The plug is pulled horizontally.
      Ask FixBot
    4. MSI 17" GP72VR Keyboard Replacement, Dismounting the SSD: step 4, image 1 of 1
      • Unscrew the screw holding the 1TB disk (red circle). The other screw was threaded through the bottom. Unplug and remove the disk.
      • The other disk, 128 GB will remain attached to the motherboard (yellow circle).
      • I chose not to separate the motherboard and the cooling system in order to avoid problems with loss of thermal conduction.
      Ask FixBot
    5. MSI 17" GP72VR Keyboard Replacement, Wi-Fi antenna and screen cables.: step 5, image 1 of 3 MSI 17" GP72VR Keyboard Replacement, Wi-Fi antenna and screen cables.: step 5, image 2 of 3 MSI 17" GP72VR Keyboard Replacement, Wi-Fi antenna and screen cables.: step 5, image 3 of 3
      • Disconnect the two coaxial antenna cables from the wifi card (blue circle). Be careful, the sockets are quite fragile. Keep the yellow insulation (Kaptan tape, if lost or not reusable cellophane tape will work).
      • Disconnect the screen ribbon cable (green circle). The lock swings upwards.
      • Locate the cable routing along the fan and under the hinge. release the cables. (Note: A photo of the routing may be helpful later as incorrectly routing them is very likely to cause damage on reassembly)
      Ask FixBot
    6. MSI 17" GP72VR Keyboard Replacement, Fan mountings.: step 6, image 1 of 3 MSI 17" GP72VR Keyboard Replacement, Fan mountings.: step 6, image 2 of 3 MSI 17" GP72VR Keyboard Replacement, Fan mountings.: step 6, image 3 of 3
      • Unscrew the screws securing the fans: two per fan. In the images the screws are unscrewed.
      Ask FixBot
    7. MSI 17" GP72VR Keyboard Replacement, Turning the Motherboard over: step 7, image 1 of 3 MSI 17" GP72VR Keyboard Replacement, Turning the Motherboard over: step 7, image 2 of 3 MSI 17" GP72VR Keyboard Replacement, Turning the Motherboard over: step 7, image 3 of 3
      • Unscrew the two screws at the bottom of the motherboard (yellow circles).
      • Lift the fans and flip the motherboard toward the bottom of the photo.
      • The two keyboard cables pass through the metal support plate and are connected to the motherboard. The small one for the lighting and the large one for the keys. (Red Circles)
      • The locks pull horizontally. The cable contacts are on top and the locks are placed under the cables between the keyboard and the cable.
      Ask FixBot
    8. MSI 17" GP72VR Keyboard Replacement, Removing the keyboard support plate: step 8, image 1 of 3 MSI 17" GP72VR Keyboard Replacement, Removing the keyboard support plate: step 8, image 2 of 3 MSI 17" GP72VR Keyboard Replacement, Removing the keyboard support plate: step 8, image 3 of 3
      • The metal plate supporting the keyboard is melt-fused to the bottom by protrusions passing through the keyboard. I broke them by forcing a flat-head screwdriver under the plate.. You can also melt them with a soldering iron. (Don't inhale the fumes!)
      • The screws securing the plate at the bottom were missing, when reassembling I used screws "inherited" from the removal of HDD disks. Diameter 2mm
      • The yellow kaptan tape(s) must be replaced when reassembling.
      • The broken keyboard to be replaced by the new keyboard
      Ask FixBot
    9. MSI 17" GP72VR Keyboard Replacement, Reassembly: step 9, image 1 of 1
      • Perform the previous steps in reverse order.
      • The holes marked with an X will be used by the screws passing through the bottom
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Claude Jobez
194 Reputation
1 Guide authored
2 Guide Comments
Bonjour,
Les rivets thermos soudés étant cassés après démontage.
Comment faites vous tenir la plaque métallique qui maintient le clavier au remontage ?
Merci
julienmaillet - Reply Share
One thing this guide doesn't cover: the key cap itself is rarely what fails. It's usually the retainer clip — the small plastic scissor mechanism that sits between the cap and the keyboard membrane. There are three main styles: butterfly (curved arms, no center peg), dual-post (two side pegs), and single-post (one center peg). They look similar but are not interchangeable — ordering the wrong one means it physically won't clip in.
To identify which type you have: look at the empty socket. The socket shape tells you the retainer style. Butterfly sockets have two curved slots on opposing sides. Dual-post have two round holes on left/right. Single-post has one round hole in the center.
Also worth noting: the rubber cup (the small silicone dome under the retainer) deteriorates over time and can cause keys to feel mushy or stop registering even when the cap and retainer are intact. If you're deep enough to pop the key, check the cup too.
Jeff Horton - Reply Share
Past 24 Hours: 9
Past 7 Days: 63
Past 30 Days: 275
All Time: 3,208
