LG env2 vx9100 Side Buttons Replacement
  1. LG env2 vx9100 Side Buttons Replacement, Battery: step 1, image 1 of 3 LG env2 vx9100 Side Buttons Replacement, Battery: step 1, image 2 of 3 LG env2 vx9100 Side Buttons Replacement, Battery: step 1, image 3 of 3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Side Buttons Replacement, Back Panel: step 2, image 1 of 2 LG env2 vx9100 Side Buttons Replacement, Back Panel: step 2, image 2 of 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Side Buttons Replacement: step 3, image 1 of 2 LG env2 vx9100 Side Buttons Replacement: step 3, image 2 of 2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Side Buttons Replacement: step 4, image 1 of 2 LG env2 vx9100 Side Buttons Replacement: step 4, image 2 of 2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Side Buttons Replacement, Side Buttons: step 5, image 1 of 2 LG env2 vx9100 Side Buttons Replacement, Side Buttons: step 5, image 2 of 2
    • Locate the volume and camera buttons on the right side of the phone.
    • Lift up on the buttons to slide them out of the phone.
Reed Williston
34 Reputation
7 Guides authored
Cal Poly, Team 16-55, Forte Fall 2012 Member of Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 490
