Up to 20% off select tools
LG WM3050CW Control Panel Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
8
All Time:
187
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the control panel in your LG WM3050CW Washing Machine.
    1. LG WM3050CW Control Panel Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Control Panel Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG WM3050CW Control Panel Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Control Panel Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Control Panel Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
      Ask FixBot
    2. LG WM3050CW Control Panel Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Control Panel Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG WM3050CW Control Panel Replacement: step 4, image 1 of 2 LG WM3050CW Control Panel Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG WM3050CW Control Panel Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG WM3050CW Control Panel Replacement, Remove the detergent drawer: step 5, image 2 of 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Ask FixBot
    2. LG WM3050CW Control Panel Replacement: step 6, image 1 of 3 LG WM3050CW Control Panel Replacement: step 6, image 2 of 3 LG WM3050CW Control Panel Replacement: step 6, image 3 of 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Ask FixBot
    1. LG WM3050CW Control Panel Replacement, Disconnect the control panel: step 7, image 1 of 3 LG WM3050CW Control Panel Replacement, Disconnect the control panel: step 7, image 2 of 3 LG WM3050CW Control Panel Replacement, Disconnect the control panel: step 7, image 3 of 3
      • Disconnect the three harness connectors for the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG WM3050CW Control Panel Replacement, Unfasten the control panel: step 8, image 1 of 2 LG WM3050CW Control Panel Replacement, Unfasten the control panel: step 8, image 2 of 2
      • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
      Ask FixBot
    3. LG WM3050CW Control Panel Replacement, Unfasten the detergent dispenser: step 9, image 1 of 1
      • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
      Ask FixBot
    4. LG WM3050CW Control Panel Replacement, Unclip the control panel: step 10, image 1 of 3 LG WM3050CW Control Panel Replacement, Unclip the control panel: step 10, image 2 of 3 LG WM3050CW Control Panel Replacement, Unclip the control panel: step 10, image 3 of 3
      • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
      • Twist the screwdriver to release the clips securing the control panel.
      • Repeat this procedure for the remaining clips along the control panel.
      Ask FixBot
    5. LG WM3050CW Control Panel Replacement, Remove the control panel: step 11, image 1 of 3 LG WM3050CW Control Panel Replacement, Remove the control panel: step 11, image 2 of 3 LG WM3050CW Control Panel Replacement, Remove the control panel: step 11, image 3 of 3
      • Lift the control panel upward to completely separate it from the chassis.
      • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
      • Remove the control panel.
      Ask FixBot
Author
with
Bill Gilbert
41,138 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 187
