Introduction
This guide will show you how to disassemble the LG Vu CU920 to replace a broken microphone. You will need to keep track of small screws, remove small components from the motherboard, and solder/unsolder a component
Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
Remove the two 3.5 mm screws above the battery port with a Phillips #00 screwdriver.
Unsolder the microphone located at the top right corner of the motherboard near the silver jack.
Solder in a replacement microphone.
One Comment
The microphone is located on a flex cable with the lower and side keys. The component shown is the external antenna connector, hence the location next to the internal antenna connector. Source: I work in cell phone repairs, soldering, and electrical circuitry.
