LG Vortex Rear Facing Camera Replacement
  1. LG Vortex Rear Facing Camera Replacement, Power down the Phone: step 1, image 1 of 1
    • Power the phone off
    • The power button is located on top of the phone
  2. LG Vortex Rear Facing Camera Replacement, Remove the Back Cover: step 2, image 1 of 3 LG Vortex Rear Facing Camera Replacement, Remove the Back Cover: step 2, image 2 of 3 LG Vortex Rear Facing Camera Replacement, Remove the Back Cover: step 2, image 3 of 3
    • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
    • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
    • Remove the back cover and set it to the side.
  3. LG Vortex Rear Facing Camera Replacement: step 3, image 1 of 1
    • Remove the battery using the blue plastic opening tool.
    • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
    • Put the battery aside.
  4. LG Vortex Rear Facing Camera Replacement, Unscrew the Back Frame: step 4, image 1 of 2 LG Vortex Rear Facing Camera Replacement, Unscrew the Back Frame: step 4, image 2 of 2
    • All screws are the same size screwdriver head #00
    • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
    • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
    • Place the screws in a container to ensure they aren't lost.
  5. LG Vortex Rear Facing Camera Replacement, Remove the Back Frame: step 5, image 1 of 3 LG Vortex Rear Facing Camera Replacement, Remove the Back Frame: step 5, image 2 of 3 LG Vortex Rear Facing Camera Replacement, Remove the Back Frame: step 5, image 3 of 3
    • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
    • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
    • Pry your way around the entire phone to separate the face from the frame.
  6. LG Vortex Rear Facing Camera Replacement, Rear Facing Camera: step 6, image 1 of 3 LG Vortex Rear Facing Camera Replacement, Rear Facing Camera: step 6, image 2 of 3 LG Vortex Rear Facing Camera Replacement, Rear Facing Camera: step 6, image 3 of 3
    • NOTE: This is the most difficult step.
    • Locate system board (silicone board with all of the circuitry on it). Notice that there is a black piece at the top of the system board (with the camera in it).
    • Use the pry bar to push the 2 black tabs away from the system board (located on the sides of the board). These tabs may snap back onto the board, so attempt to hold them off of the board.
    • Use the pry bar to pry the black piece at the top of the phone (looks to be attached to the system board, but is not).
  7. LG Vortex Rear Facing Camera Replacement: step 7, image 1 of 1
    • NOTE: Do not damage the thin wires attaching the motherboard to the speakers
    • Using the blue plastic prying tool remove the black piece next to the camera.
  8. LG Vortex Rear Facing Camera Replacement: step 8, image 1 of 1
    • NOTE: Remove with caution.
    • Disconnect the cord attaching the camera to the system board.
    • (It looks like a thin piece of plastic)
  9. LG Vortex Rear Facing Camera Replacement: step 9, image 1 of 3 LG Vortex Rear Facing Camera Replacement: step 9, image 2 of 3 LG Vortex Rear Facing Camera Replacement: step 9, image 3 of 3
    • The camera is held on by 1 sticker on the top of the camera.
    • Remove this sticker using your fingernail.
    • Pull the camera off the system board using your fingers. Perform this step with caution.
  10. LG Vortex Rear Facing Camera Replacement: step 10, image 1 of 1
    • Place new camera in the same location, and place the sticker back on its side.
  11. LG Vortex Rear Facing Camera Replacement: step 11, image 1 of 1
    • Reverse the steps to reassemble the phone.
Jen
22 Reputation
3 Guides authored
Ohio State, Team 1-3, Buehl Spring 2014 Member of Ohio State, Team 1-3, Buehl Spring 2014
OSU-BUEHL-S14S1G3
4 Members
6 Guides authored
4 Comments
First, clean the cookware with water and a mild kitchen soap to remove anything that might be on the surface. Rinse with hot water. I do uk.bestessays.com and Then coat the entire bottom of the pan in vegetable oil in this case, canola oil and turn it over onto a paper towel for 10 minutes.
William Peter - Reply
Offer massages in my sanctuary or in the comfort of your own home
<a href="https://thecarriagehousesanctuary.square...">Top Massage Therapist in Westchester County NY</a>
Junaid Khan Akazai - Reply
Offer massages in my sanctuary or in the comfort of your own home <a href="https://thecarriagehousesanctuary.square...">Best Massage Therapist in Westchester County NY</a>
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 275
