LG Volt Motherboard Replacement
    1. LG Volt Motherboard Replacement, Motherboard: step 1, image 1 of 3 LG Volt Motherboard Replacement, Motherboard: step 1, image 2 of 3 LG Volt Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Pry back cover with finger in the crease.
      • Remove back casing.
      Ask FixBot
    2. LG Volt Motherboard Replacement: step 2, image 1 of 3 LG Volt Motherboard Replacement: step 2, image 2 of 3 LG Volt Motherboard Replacement: step 2, image 3 of 3
      • With your finger, pry the battery out through the crease made for removal.
      Ask FixBot
    3. LG Volt Motherboard Replacement: step 3, image 1 of 3 LG Volt Motherboard Replacement: step 3, image 2 of 3 LG Volt Motherboard Replacement: step 3, image 3 of 3
      • Remove all 11 (4mm) screws with the JIS #000 screwdriver
      • There are three screws on top, three above the battery, one next to the battery, one under the battery and three at the bottom of the phone.
      Ask FixBot
    4. LG Volt Motherboard Replacement: step 4, image 1 of 3 LG Volt Motherboard Replacement: step 4, image 2 of 3 LG Volt Motherboard Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to remove the back housing from the frame of the phone.
      Ask FixBot
    5. LG Volt Motherboard Replacement: step 5, image 1 of 2 LG Volt Motherboard Replacement: step 5, image 2 of 2
      • Carefully lift all the indicated tabs.
      • Carefully unplug the marked cables.
      Ask FixBot
    6. LG Volt Motherboard Replacement: step 6, image 1 of 2 LG Volt Motherboard Replacement: step 6, image 2 of 2
      • Remove motherboard carefully.
      Ask FixBot
    7. LG Volt Motherboard Replacement: step 7, image 1 of 1
      • Put new motherboard in place of old motherboard.
      • Follow steps 6 through 1 in that order for reassembly.
      Ask FixBot
Adrian Soldan
464 Reputation
4 Guides authored
USF Tampa, Team S3-G3, Cannon Fall 2017 Member of USF Tampa, Team S3-G3, Cannon Fall 2017
USFT-CANNON-F17S3G3
3 Members
32 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 885
