Introduction
Steps to remove LG VX8550 screen
Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
Carefully lift up on the motherboard to see the ribbon cables underneath.
Use the spudger to carefully disconnect the ribbon cable from the motherboard.
Peel back but don't remove the blue tape to access the 2 center screws.
Remove the 6 slider screws with the Phillips #00 screwdriver.
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
Grasp the ribbon cable near the connector and carefully slide it out of the white connector.
