Installing LG VX5500 Screen
  1. Installing LG VX5500 Screen, Battery: step 1, image 1 of 3 Installing LG VX5500 Screen, Battery: step 1, image 2 of 3 Installing LG VX5500 Screen, Battery: step 1, image 3 of 3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. Installing LG VX5500 Screen, Screen: step 2, image 1 of 2 Installing LG VX5500 Screen, Screen: step 2, image 2 of 2
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  3. Installing LG VX5500 Screen: step 3, image 1 of 2 Installing LG VX5500 Screen: step 3, image 2 of 2
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  4. Installing LG VX5500 Screen: step 4, image 1 of 3 Installing LG VX5500 Screen: step 4, image 2 of 3 Installing LG VX5500 Screen: step 4, image 3 of 3
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  5. Installing LG VX5500 Screen: step 5, image 1 of 2 Installing LG VX5500 Screen: step 5, image 2 of 2
    • Use the tweezers to lift the display adapter off the screen component.
  6. Installing LG VX5500 Screen: step 6, image 1 of 2 Installing LG VX5500 Screen: step 6, image 2 of 2
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  7. Installing LG VX5500 Screen: step 7, image 1 of 2 Installing LG VX5500 Screen: step 7, image 2 of 2
    • Remove the earpiece by lifting it out of the phone casing using tweezers.
    • The earpiece is adhered to the phone casing so it will take a small amount of force to remove it.
  8. Installing LG VX5500 Screen: step 8, image 1 of 2 Installing LG VX5500 Screen: step 8, image 2 of 2
    • Remove the vibration motor by lifting it out of the phone casing using tweezers.
    • The motor is adhered to the phone casing so it will take a small amount of force to remove it.
  9. Installing LG VX5500 Screen: step 9, image 1 of 1
    • Lift the screen components out of the phone.
Henry
181 Reputation
3 Guides authored
Cal Poly, Team 7-33, Maness Spring 2012 Member of Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 3,763
