LG VX4500 keyboard replacement duplicate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. LG VX4500 keyboard replacement duplicate, Battery: step 1, image 1 of 1
    • Before removing the battery, ensure that the phone is turned off.
    • To remove the battery from your LG VX4500, turn the phone so that the back panel is showing.
  2. LG VX4500 keyboard replacement duplicate: step 2, image 1 of 1
    • Pull back on the white release tab and lift up the the entire battery.
  3. LG VX4500 keyboard replacement duplicate: step 3, image 1 of 1
    • The back panel should now be fully accessible.
  4. LG VX4500 keyboard replacement duplicate, LG VX4500 Disassembly: step 4, image 1 of 2 LG VX4500 keyboard replacement duplicate, LG VX4500 Disassembly: step 4, image 2 of 2
    • Using a paper clip, remove all 4 rubber screwcaps from the screw ports.
    • With a Phillips head screwdriver, remove all 4 screws from their ports.
    • Also remove the rubber screwcap in the upper part of the back panel along with the screw under it.
    • The fifth screw will be more difficult to get out because the plastic port has much higher sides.
  5. LG VX4500 keyboard replacement duplicate: step 5, image 1 of 3 LG VX4500 keyboard replacement duplicate: step 5, image 2 of 3 LG VX4500 keyboard replacement duplicate: step 5, image 3 of 3
    • Run a plastic opening tool along the seam to seperate the keyboard cover and the back panel
    • Remove the back panel, now the logic board, keyboard and microphone are exposed.
  6. LG VX4500 keyboard replacement duplicate, Logic Board: step 6, image 1 of 2 LG VX4500 keyboard replacement duplicate, Logic Board: step 6, image 2 of 2
    • With your fingers, gently lift up the gold connector until it is completely disconnected.
  7. LG VX4500 keyboard replacement duplicate, Keyboard: step 7, image 1 of 1
    • Move the logic board out of the way to reveal the keyboard underneath.
  8. LG VX4500 keyboard replacement duplicate: step 8, image 1 of 2 LG VX4500 keyboard replacement duplicate: step 8, image 2 of 2
    • Pop the keyboard out using a your finger until the entire keyboard is out.
iDeleted
2,101 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 345
