LG VX4500 display interconnect cable
    1. LG VX4500 display interconnect cable, Battery: step 1, image 1 of 1
      • Turn the closed phone so that the back panel is facing you.
      • Press down and forward firmly on the gray tab in the middle of the phone.
      Ask FixBot
    2. LG VX4500 display interconnect cable: step 2, image 1 of 2 LG VX4500 display interconnect cable: step 2, image 2 of 2
      • Now just lift up on the battery and remove it from the phone.
      Ask FixBot
    1. LG VX4500 display interconnect cable, Rear Cover: step 3, image 1 of 1
      • Remove the rubber grommet using a spudger.
      Ask FixBot
    2. LG VX4500 display interconnect cable: step 4, image 1 of 1
      • Be sure not to lose the screws. They are small!
      • Remove the five screws using a Phillips #00 Screwdriver.
      Ask FixBot
    3. LG VX4500 display interconnect cable: step 5, image 1 of 3 LG VX4500 display interconnect cable: step 5, image 2 of 3 LG VX4500 display interconnect cable: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • When removing back cover, be careful not to break the speaker wires.
      • Using an Opening Tool, carefully pry off the back cover.
      • Using tweezers, gently pull the speaker wires out.
      Ask FixBot
    4. LG VX4500 display interconnect cable: step 6, image 1 of 1
      • Separate the two halves.
      Ask FixBot
    1. LG VX4500 display interconnect cable, Keypad: step 7, image 1 of 3 LG VX4500 display interconnect cable, Keypad: step 7, image 2 of 3 LG VX4500 display interconnect cable, Keypad: step 7, image 3 of 3
      • Carefully pry and lift up on the logic board using an iPod Opening Tool.
      Ask FixBot
    2. LG VX4500 display interconnect cable: step 8, image 1 of 1
      • Carefully flip the logic board up and out of the way.
      Ask FixBot
    3. LG VX4500 display interconnect cable: step 9, image 1 of 3 LG VX4500 display interconnect cable: step 9, image 2 of 3 LG VX4500 display interconnect cable: step 9, image 3 of 3
      • Use an iPod Opening Tool to lift up on the keypad and pull it out.
      Ask FixBot
    1. LG VX4500 display interconnect cable, Motherboard: step 10, image 1 of 1
      • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
      • Use a soldering iron to desolder the solder joint on the front of the motherboard.
      • If you need more information on soldering, refer to this guide.
      Ask FixBot
    2. LG VX4500 display interconnect cable: step 11, image 1 of 1
      • Desolder the joint on the back using a soldering iron.
      Ask FixBot
    3. LG VX4500 display interconnect cable: step 12, image 1 of 3 LG VX4500 display interconnect cable: step 12, image 2 of 3 LG VX4500 display interconnect cable: step 12, image 3 of 3
      • Carefully detach the ribbon cable and remove the motherboard.
      Ask FixBot
    1. LG VX4500 display interconnect cable, Outer Display Cover: step 13, image 1 of 1
      • Remove 4 rubber grommets using the Spudger.
      Ask FixBot
    2. LG VX4500 display interconnect cable: step 14, image 1 of 1
      • Remove 4 screws using the Phillips #00 Screwdriver.
      Ask FixBot
    3. LG VX4500 display interconnect cable: step 15, image 1 of 3 LG VX4500 display interconnect cable: step 15, image 2 of 3 LG VX4500 display interconnect cable: step 15, image 3 of 3
      • Carefully pry off outer cover using iPod Opening Tool.
      Ask FixBot
    1. LG VX4500 display interconnect cable, Display: step 16, image 1 of 2 LG VX4500 display interconnect cable, Display: step 16, image 2 of 2
      • Remove speaker using the Spudger.
      Ask FixBot
    2. LG VX4500 display interconnect cable: step 17, image 1 of 2 LG VX4500 display interconnect cable: step 17, image 2 of 2
      • Remove vibrator using the Spudger.
      Ask FixBot
    3. LG VX4500 display interconnect cable: step 18, image 1 of 2 LG VX4500 display interconnect cable: step 18, image 2 of 2
      • Lift up LCD display using iPod Opening Tool.
      Ask FixBot
    4. LG VX4500 display interconnect cable: step 19, image 1 of 1
      • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
      • De-solder solder joint using Soldering Iron.
      Ask FixBot
    5. LG VX4500 display interconnect cable: step 20, image 1 of 2 LG VX4500 display interconnect cable: step 20, image 2 of 2
      • Pry off ribbon cable using iPod Opening Tool.
      Ask FixBot
    1. LG VX4500 display interconnect cable, Ribbon Cable: step 21, image 1 of 3 LG VX4500 display interconnect cable, Ribbon Cable: step 21, image 2 of 3 LG VX4500 display interconnect cable, Ribbon Cable: step 21, image 3 of 3
      • Turn phone so that the back side is facing you.
      • Press blue button and remove top half using Spudger.
      Ask FixBot
    2. LG VX4500 display interconnect cable: step 22, image 1 of 2 LG VX4500 display interconnect cable: step 22, image 2 of 2
      • Remove cable from bottom section.
      Ask FixBot
David Foster
1 Reputation
8 Guides authored
Cal Poly, Team 25-88, Amido Spring 2010 Member of Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 3,422
