LG VX3200 Keypad Replacement
  1. LG VX3200 Keypad Replacement, Battery: step 1, image 1 of 1
    • Press button labeled "Push". In the photo depicted the button is being depressed by the left finger.
    • Pull back panel toward bottom of phone.
  2. LG VX3200 Keypad Replacement: step 2, image 1 of 1
    • From the lip on the top of the battery, lift it out of the phone.
  3. LG VX3200 Keypad Replacement, Keypad: step 3, image 1 of 1
    • Remove the 4 small screws from the back panel, under the battery.
  4. LG VX3200 Keypad Replacement: step 4, image 1 of 1
    • Starting at the top of the phone near the antenna, use a screwdriver or other small tool, maybe even fingernails, to pry the rear panel off.
    • There are 4 places where the panel snaps together to the main part of the phone.
    • By systematically prying up the edges of the back panel, moving about a quarter of an inch, and prying again, the panel will begin to lift off.
    • Don't be afraid to damage anything, the panel requires a bit of force to detach.
  5. LG VX3200 Keypad Replacement: step 5, image 1 of 2 LG VX3200 Keypad Replacement: step 5, image 2 of 2
    • The logic board is only held on with 4 tabs. Simply pry from one side using a screwdriver, popping out the board.
  6. LG VX3200 Keypad Replacement: step 6, image 1 of 1
    • Lift the keypad up from beneath the logic board.
    • It is not glued or secured in any way, so it should come away easily.
Bradley Hutchinson
42 Reputation
5 Guides authored
Cal Poly, Team 5-9, Forte Winter 2010 Member of Cal Poly, Team 5-9, Forte Winter 2010
CPSU-FORTE-W10S5G9
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,007
