LG V20 Battery Replacement
  1. LG V20 Battery Replacement, Back Cover: step 1, image 1 of 3 LG V20 Battery Replacement, Back Cover: step 1, image 2 of 3 LG V20 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
    • Remove the back cover.
  2. LG V20 Battery Replacement, Battery: step 2, image 1 of 3 LG V20 Battery Replacement, Battery: step 2, image 2 of 3 LG V20 Battery Replacement, Battery: step 2, image 3 of 3
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Use the flat end of a spudger and insert it in the small recess at the lower end of the battery.
    • Use the spudger to lever out the battery and remove it.
    • You can do this with your fingers but take care not to puncture the battery with your fingernails.
Garrett Janney
897 Reputation
4 Guides authored
Cal Poly, Team S22-G5, Livingston Spring 2017 Member of Cal Poly, Team S22-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G5
4 Members
36 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 9,161
